It is currently Fri Oct 30, 2026 11:02 pm
PostPosted: Wed Oct 25, 2017 11:37 pm
[list=][/list]What are integrated cpu motherboards classified as
PostPosted: Thu Oct 26, 2017 12:13 am
They vary across the spectrum from midgrade to cell phone board class.
In this case depending on the back as posted peripheral
PostPosted: Fri Oct 27, 2017 3:19 am
U sure I would call it a large socket mb and or laptop mb
PostPosted: Sat Oct 28, 2017 10:23 pm
Laptop motherboards generally get classed as large socket.
Soldered cpu boards like all in one computers, embedded systems, raspberry pi, netbooks, tablets....
Embedded systems like those using the via architecture and intel atom will normally get small socket. Peripheral is possible.
Netbooks and ultralights tends to be peripheral but small socket and telco are possible
Most notebook/laptop boards are large socket
Tablets range from peripheral on the low end to telco for slates and cell class for some slates and phablets.
Micro pc boards on the micro itx form tend to be midgrade or more often peripheral. Some super power micros like from AMD/AsRock and via will make telco
Unfortunately I’m quite sure the one you posted will go on peripheral. It’s missing too many of the motherboard checklist items. Such as Bridge chips, gold expansions, memory slots or onboard memory.
As a note if a system uses an embedded gpgpu or gpcpu it’s likely to fall into peripheral unless it’s a slate tablet or phablet/phone.
