It is currently Sun Nov 01, 2026 11:32 pm
 Post subject: How bad did I mess up.
PostPosted: Sun Nov 12, 2017 2:57 am
I don't have a heat gun so I cut one off to look at it. Turns out they are double sided. They have a small amount of pin on them still and are gold on both sides. they are also ceramic. The one with the most damage is bottom right.
PostPosted: Sun Nov 12, 2017 1:48 pm
They all look ohkay. I’ve seen far worse.
I’ve SENT far worse without issue.
PostPosted: Sun Nov 12, 2017 7:38 pm
same.here you be fine with those
PostPosted: Mon Nov 13, 2017 11:05 am
They would now be considered stub pin processors.
The worst case is having it fall into pentium ceramic. And you should have enough pin left to not. But ultimately cutting soldered CPUs off a board is not the best idea.
