It is currently Tue Nov 03, 2026 5:24 am
 Post subject: Id help
PostPosted: Mon Nov 20, 2017 11:30 pm
What about this mobo? Could it fetch anything higher than large socket with all those ic chips in the bottom of the board and the multiple slots?
 Post subject: Re: Id help
PostPosted: Tue Nov 21, 2017 12:19 am
i doubt it you see the prices here are averages so boards like yours that are a higerer grade than largesocket but still in that grade would be a + for them while boards like low spec laptops motherboards(also largesocket) are a - for them averaging out .
but if you want to see if you can get a better price you need to email CHRIS.chris@boardsort.com
PostPosted: Tue Nov 21, 2017 5:45 pm
What you’ve got there is a PCI-X board. I’ve never had one get anything beyond large socket. PCI-X for extended was an experiment in cost cutting. The fact that most fall into large socket is actually detrimental to boardsort’s bottom line.
They’re worth considerably less than say, a Pentium II or AMD 6/7 series slot cpu board.
