It is currently Tue Oct 27, 2026 1:29 am
PostPosted: Fri Dec 22, 2017 9:33 am
These are all front and back pics
Not sure if trimming G F would degrade the board/boards
And the one with the hard drive is that considered small socket?
And the last pic is it memory?
Is that a battery in the last pic?
PostPosted: Fri Dec 22, 2017 5:30 pm
Wow, throw me a holiday curveball eh? ;)
Looks like a lot of class benders so I’ll be back in a short while. Want to go back through photos of what I sent in and how they were ultimately classed out.
PostPosted: Fri Dec 22, 2017 5:56 pm
B06EA3FF8C7F Is peripheral
1BCAC1655697/70FC4BD3CCE7
This is tough. With the finger on, those flip chip ICs should all have silveride caps on the bottom if they’re original... no steel excess; just barely telco is my thought
5817AB88202A/8331CC38B88E
Another edge case. There’s more junk on this but those pulse transformers have silver and manganese, not copper and iron. The gold pin port. And a massive finger. Again I lean telco on the lowest end of it
384C47DD7DFC/D931E6BDB2BA
Peripheral. No question on this one
79AA9AE455E7/3CF67201881A
Peripheral. Trim the finger and remove the hard drive
A29F851AE3AC/535710D0A719
Again lean low end of telco. Data sheet says the box is a regulator not a battery. But the product design doesn’t match up. Even without a case or cover it would be totally the wrong form factor. So I question if the number has been reused
Wait a day or so for mls to chime in: and if they don’t follow my battery rule. When in doubt remove it. It’s not worth the danger.
