It is currently Wed Aug 05, 2026 12:23 pm
 Post subject: Peripheral?
PostPosted: Tue Dec 26, 2017 12:04 am
I assume peripheral but not too sure.
 Post subject: Re: Peripheral?
PostPosted: Tue Dec 26, 2017 8:19 am
Most of what you have there would go peripheral, but I would let lostinlodos chime in on a couple of them that appear to have good IC density along with the flat pack. Two of the boards do appear to have heat sinks on their flat packs. Try to remove them if possible. One can be removed with pliers and some elbow grease, while the other appears that it can be removed with a small flathead screwdriver to pop the heat sink loose at the solder joint on the board.
PostPosted: Tue Dec 26, 2017 9:44 am
All are peripheral.
