It is currently Sat Oct 31, 2026 2:16 am
PostPosted: Sat Feb 24, 2018 2:04 pm
All,
Put me out of my misery . . .
Do I even want to mess with this 3-part, 1,500 lb beast? Is there anything else other than the dual Xeon processors, 4GB memory and telco grade PCBs worth the effort? I can get it for free.
Help!
James
PostPosted: Sat Feb 24, 2018 2:18 pm
For free??? I would would give a shot.
PostPosted: Sat Feb 24, 2018 11:00 pm
Yep. I’d be game. 1500lbs of high grade CBM class at a large yard is 1500*.35 for $525 if you did absolutely nothing. These will have a good amount of wire and telco boards as well a lot of gold plate and/or silveride; and copper. Lots of copper.
If you’re looking for a buy offer suggestion I’d be firm at 500 starting around $350. At $500 you can walk away break even if it turns out to not be enjoyable.
If it was free I’d be all over it in a second. You make money even figuring truck/trailer rentals before you pull out!
Yes you said free, being through.
