It is currently Fri Oct 30, 2026 11:53 pm
PostPosted: Sat Feb 24, 2018 2:41 pm
Front and back sides. Is this considered pin board or just backplane?
PostPosted: Sat Feb 24, 2018 10:53 pm
This is edge case that will probably make it into pin board. Though pin board normally is something not recognisable as being for ports, but like the sibling quasi class of peg board is designed for wire wrap application.
When you fill out the quote you should put it under backplane but email Chris afterwards with your order number and let him know you have a pin heavy board in the order. If it clears pin board, believe it will, they’ll make the adjustments on reception.
