It is currently Tue Sep 29, 2026 12:45 am
PostPosted: Sat Mar 24, 2018 5:19 pm
Unsure of the sort for these. Thought I was getting the hang of things but it turns out I couldn't even remember my login ha.
PostPosted: Sat Mar 24, 2018 6:33 pm
First set
Two gold finger cards (you can pull the socketed ICs) a slot processor and a bus card.
The card needs to be removed from the shell. It will be between peripheral and telco class.
Second set.
Telco on the left, other two gold finger card.
Both motherboards are large socket.
PostPosted: Sat Mar 24, 2018 7:06 pm
Thank you and shouldn't I just leave those ICs on for them?
PostPosted: Sat Mar 24, 2018 7:10 pm
You can or you can pull th m for submission in the ic class.
PostPosted: Sat Mar 24, 2018 7:20 pm
Okay I'll probably leave those on. I'm going to separate another 30 or more computers and sort before I ask to come in. I don't think there would be enough to separate them would it?
PostPosted: Sat Mar 24, 2018 11:22 pm
They prefer a few pounds but as long as you’re at aleast at a pound it’s ohkay to pull them.
PostPosted: Sun Mar 25, 2018 9:15 am
Thank you, had trouble removing them and I don't think there will be enough weight for the work when I'm done to start the IC class. Plus I already packed up most of my boards that have those. Couldn't get the shell off the bus card either last night without damaging it so I'll give it another try today.
Figured out how to do the socket IC chips right. If I do them don't mix them with other kinds of ICs that have legs right?
PostPosted: Sun Mar 25, 2018 4:36 pm
The ic rate is for any integrated circuit without gold legs.
Be they a junk i/o controller or a nickel-tin pin Pentium.
Here’s Boardsort’s photo
And a more generic one
The ic class doesn’t contemplate the pins.
Any ic with gold pins will fall into a processor category somewhere. Without pins or with non gold pins they are IC class.
PostPosted: Sun Mar 25, 2018 7:17 pm
Thank you for gettin me goin right on that.
cron
