It is currently Tue Sep 29, 2026 9:30 am
 Post subject: Gold plated or brass?
PostPosted: Wed Mar 28, 2018 10:16 pm
Will these jacks be gold plated or brass? They are in mobile VCR's.
PostPosted: Wed Mar 28, 2018 10:44 pm
A very thin gold plating the vast majority of the time.
PostPosted: Wed Mar 28, 2018 11:33 pm
If I leave them on the plastic frame they can go as gold pin connector right?
Would I get a better price if I pull them off the plastic frame and knock the colored ring out?
PostPosted: Thu Mar 29, 2018 12:50 am
Unfortunately no. They won’t qualify either way. Unlike the male connectors this has far less qualifying gold area than the gold pin connector class requires; at least since my last shipment.
PostPosted: Thu Mar 29, 2018 7:27 am
O wow. I thought what it may lack in density it would be made up in surface area.
PostPosted: Thu Mar 29, 2018 1:07 pm
I’ve asked about these specifically before because many old phonograph units have gold “rca” connectors. Male is gold pin connector female is not.
On the other hand you could smash them and pull the plastic out (as you asked) and put the empty metal shell in gold pin connector but it’s really not worth the time. I toss these in my low end copper or aluminium breakage for my local yard.
Like gold “tone” costume jewellery, there IS gold but the quantity isn’t worth recovery. Even an XRF scanner won’t pick it up.
