It is currently Thu Oct 29, 2026 8:07 am
 Post subject: power supply card??
PostPosted: Wed Aug 13, 2014 11:35 am
Need to know if I should remove anything from this plus what to place it under it is out of a power supply
 Post subject: Re: power supply card??
PostPosted: Wed Aug 13, 2014 1:44 pm
This would be a low grade board. I would remove the easy copper and ICs and leave the rest, as my local yard buys low grade boards for the same price as transformers.
PostPosted: Wed Aug 13, 2014 7:24 pm
Just be careful as components may still have a charge if you decide to take it apart
PostPosted: Wed Aug 13, 2014 8:15 pm
Thank you I will pull the copper it has no stored power I got bounced by that.
I might leave it populated since I dont know what I C s are and just toss the lot.
I need to learn some about electronics twice this week I put my hand in the wrong place one was a analog TV hand was numb for a few mins after that dumb trick
PostPosted: Wed Aug 13, 2014 8:36 pm
When scrapping power supplies, I always let them sit idle for a few days to let the main capacitors drain before opening them up. On the larger capacitors, what you can do is wrap electrical tape around the shank of a flathead screwdriver, then while wearing a safety glove to insulate your hand, hold the screwdriver across the two pins on the bottom of the board where the capacitor is soldered. That will make a short and any electricity stored in the capacitor will be discharged. You may hear a pop and see a spark when you do this. If it does spark, wait about 30 minutes, then repeat the process again. If no spark, then go ahead and scrap.
PostPosted: Fri Aug 15, 2014 6:02 pm
Here is one ic...
PostPosted: Fri Aug 15, 2014 7:32 pm
thank you
