It is currently Fri Oct 30, 2026 1:56 am
 Post subject: Teleco?
PostPosted: Thu Aug 02, 2018 6:57 am
These make Telco?
 Post subject: Re: Teleco?
PostPosted: Thu Aug 02, 2018 10:43 am
Looks good for telco
PostPosted: Thu Aug 02, 2018 12:06 pm
Thanks. I was wondering the board on right has large mounted chip in lower right corner. Would it make a difference if I removed it?
PostPosted: Thu Aug 02, 2018 7:45 pm
The Zylog? No it’s fine to remove that one.
PostPosted: Thu Aug 02, 2018 8:09 pm
Lol. Ok... But in layman's terms is it worth plucking?
PostPosted: Thu Aug 02, 2018 9:18 pm
Another example of "is it worth plucking"?
PostPosted: Thu Aug 02, 2018 9:19 pm
If it has gold pins it’s going to be a Pentium Mac ceramic class
With nickel pins it’s just an IC. ICs alone are worth less then telco by weight.
Second board is midgrade so yes remove the ic for IC rate
PostPosted: Thu Aug 02, 2018 10:54 pm
Thank you I appreciate the knowledge and I apologize in advance as I have 2 50 gallon drums full of goodies to short and my knowledge doesn't extend past ripping things apart...lol
PostPosted: Thu Aug 02, 2018 11:11 pm
Will these grade better than Telco? Identical boards front and back.
