It is currently Sat Oct 31, 2026 5:47 am
 Post subject: sorting
PostPosted: Fri Aug 03, 2018 4:07 pm
what grade would these cards fall under thanks in advance for any help
 Post subject: Re: sorting
PostPosted: Fri Aug 03, 2018 4:17 pm
First photo peripheral with the CPU on the board: without it midgrade
Second photo
Peripheral
Telco
Telco
PostPosted: Mon Aug 06, 2018 3:56 pm
one more
PostPosted: Mon Aug 06, 2018 7:29 pm
Knowledgecomputers wrote:
one more
But there’s two!???!
Telco (remove the Dallas battery box)
Telco
PostPosted: Tue Aug 07, 2018 11:17 am
thank you sir a few more for you if you dont mind im in the middle of a decent sort pile right now heat sinks will be removed
PostPosted: Tue Aug 07, 2018 2:55 pm
9) dual small socket
8) peripheral
7) peripheral
6) I’m guessing here. But think it just nudges into telco. Issue is this is missing the three Drive ports despite having the controller. Three big d shaped outlines. Old design used 3-1 SCSI and the boards go peripheral due to the steel weight. Newer versions of this series use 8-1 SAS there and go telco, the extra gold and extra BGA IC bumping it over. Leaving this in a limbo for them to decide when they hold the board themselves.
PostPosted: Tue Aug 07, 2018 4:37 pm
another few 10 is the top and bottom of the same card
PostPosted: Wed Aug 08, 2018 7:05 pm
11)looks good for small socket. Soldered CPU, bridge chips, internal expansion, external ports, and (a) ram socket.
10)textbook telco
PostPosted: Thu Aug 09, 2018 4:58 pm
some cpu's
PostPosted: Thu Aug 09, 2018 6:38 pm
1)the original Power Line chips are 486 class
2)All K5s are class benders of some sort. This one will most likely go as Motorola/Foreign
3)double sided gold cap
4) Motorol/foreign gold cap
