It is currently Mon Nov 02, 2026 6:49 am
PostPosted: Sun Nov 09, 2014 11:58 am
Can anyone tell what these are, photos enclosed. Thanks
PostPosted: Sun Nov 09, 2014 12:13 pm
First you got a slot processor, w plastic case and heat sink. Go ahead and break it out of there. Next is the motherboard it came from. Then next pic is a heat a copper/aluminum heatsink. Take that fan off to sell. Next is a gold finger card w aluminum heatsink, use a screwdriver and pop it off. The next motherboard is a metal socket motherboard, that's where no pin cpu chips come from, socket 775 I believe. Last is another gold finger card.
PostPosted: Sun Nov 09, 2014 12:26 pm
Thanks so much for your help. Are they worth anything to sell or its it basically worth the gold, alum. etc.?
PostPosted: Sun Nov 09, 2014 12:35 pm
Well if you know they work you could sell them for used items. As far as scrap goes the first mono is a LG socket, $2.80/lb, at about 1.5 lbs I'd say, then gold finger cards are maybe $3.75, and Id say 1lb tops by the two you have. Then the metal socket board is in it's own category now at $.95/lb, but there a little heavier, so that board may be just under 2 lbs. Slot cpus are 10.50/lb, just over an ounce a chip I believe, so you got what, 10 in scrap tops. If you'll be getting more save it up. Or try selling it online if they work, and you know they do. Don't waste your postage sending just that into boardsort.
