It is currently Sat Nov 07, 2026 12:22 pm
 Post subject: hello got some questions
PostPosted: Sun Mar 16, 2014 5:32 am
ok got some questions what i need to know is whats grade these go under and if possible on the 2 processors i would also like to know the weight of them..or ball park figure..
PostPosted: Sun Mar 16, 2014 8:56 am
some more unknown grades
PostPosted: Sun Mar 16, 2014 9:24 pm
The power supply board is low-grade. Sell as-is to boardsort or to your local scrap yard if they take that type of material. It's up to you if you want to take the time to remove the aluminum and CBMs from the board and sell those separately.
the card from the laptop dock would go as mid-grade most likely.
The two other cards in your first post are peripheral at best.
Most of the boards in your second post are peripheral grade, but the Tivo power supply board may fetch low grade pricing depending on board color and components attached to it. If any of your boards have heatsinks on them, take them off and sell with your aluminum or copper.
PostPosted: Sun Mar 16, 2014 11:29 pm
excellent.this how i figured ,now i just need to figure out the Motorola XPC750ARX266PE weight and grade and im all set
