It is currently Wed Oct 28, 2026 6:09 am
 Post subject: Gold Finger Cards?
PostPosted: Mon Nov 17, 2014 4:26 am
What grade are these boards. Also Can I remove the AMD Pinless CPU from the first board without downgrading it.
 Post subject: Re: Gold Finger Cards?
PostPosted: Mon Nov 17, 2014 10:36 am
The first four pictures definitely are gold cards. The bottom board in the fourth picture could go for telecom due to the large amount of ic chips. At worst is gold card. For the fifth picture the bottom three are Air Cards and it used to pay $6 per pound before the gold prices drop. The two top boards in the fifth picture are gold cards as well.
PostPosted: Mon Nov 17, 2014 10:45 am
The first card could go as telecom given you have the CPU chip on there. If you trim the fingers off, it will go as a small socket motherboard.
PostPosted: Mon Nov 17, 2014 5:56 pm
Hi If I removed the cpu from the first picture would it still go as a gold finger card?
Also why is the second picture not Gold RAM.
According to this post
http://boardsort.com/escrapforum/viewtopic.php?f=4&t=594&hilit=air+card
The top right board in picture 5 of my post should go as air cards, or has that changed?
Thanks
