It is currently Fri Oct 30, 2026 12:39 pm
 Post subject: Power supply Questions
PostPosted: Sun Dec 14, 2014 10:25 pm
If im taking a trip and have room will they buy power supplies like they are or does the boards need out? Obviously I would get more out of them if the boards were out but, Im running out of time to get it all torn apart before Im headed that way and also need to get them out of the way. Thank you for any input!
PostPosted: Mon Dec 15, 2014 7:55 am
According to payouts they pay $0.24 lb for power supplies with wire
PostPosted: Mon Dec 15, 2014 11:08 am
If you don't want to sell your power supplies with the wire or had already trimmed the wire, I would pull off the aluminum heat sinks and any transformers with exposed copper and separate them. Don't fool with the transformers that have all that tape on them because it's a pain to get off and the little #2 that you get isn't worth the time and energy.
PostPosted: Tue Dec 16, 2014 4:56 pm
those are not gold connecter ends on the power supply pigtails....am i correct?
PostPosted: Tue Dec 16, 2014 5:41 pm
I've yet to find one that did contain gold plating. I would think that the metal used would be brass or tin.
PostPosted: Thu Jan 01, 2015 2:33 pm
The common power supply's from home pcs leave together, you'll make more for your time. The commercial ones have mid grade boards inside, usually no wire. Worth the time to take apart, esp cuz all depending whos on the scale one day they may pay you for power supply with wire because theyre commercial ones, then the next day $.15 a lb. I recently stumbled on about 50 Silicon Graphics systems, older Indigos, Challenge S Series, Indys, etc, and the power supplys in them have alot of gold plated pins, so on higher grade pcs and servers, take a look.
