It is currently Thu Oct 29, 2026 1:52 pm
 Post subject: Help with these boards
PostPosted: Thu Sep 13, 2018 12:45 pm
So I have an array of boards from various places that have been ripped apart over the last year. It'll cost me about 50 cents a pound to ship these in, so economically makes no sense to deal with anything here that isn't peripheral or better it seems.
For that, the board is going to need to be green on both sides at the least, yes?
Any brown board such as comes out of a power supply, CRT monitor, VCR, etc would be low grade, yes? I dump it off for a couple pennies at the local yard.
I've removed the batteries I know about in all the attached pictures, but browsing through the forums I see comments about batteries in pictures that I don't even see. If you spot one let me know.
I've attached pictures for any further questions:
PostPosted: Sat Sep 15, 2018 6:36 pm
Basic question is if anything in those pictures look like peripheral or better?
Gonna have to get this stuff out of my shop, I have a bed I need to get started on soon. Thanks.
PostPosted: Sun Sep 16, 2018 2:13 pm
I’ll be back. Try to do this today for you. Yes lots better than peripheral
PostPosted: Wed Sep 19, 2018 2:04 pm
Just checking in. Anybody able to help me out on those?
PostPosted: Wed Sep 19, 2018 9:40 pm
large if the contacts are copper or gold, peripheral; other 3 peripheral
top don't know, flip it over, midgrade gold finger card, low grade
the two network boards are peripheral, please pop the shields and heatsink off. The lower one MAY have a battery box on it. rest are midgrade.
left top low grade
left bottom peripheral
right top peripheral
right middle up midgrade
right middle down peripheral
right bottom, depends on back, flip it
centre low grade
left
peripheral
peripheral
peripheral/midgrade
midgrade
right
telco
telco
left (switch)
peripheral
centre
peripheral
low grade (remove the copper, yes)
peripheral
right
peripheral
low grade
peripheral
left midgrade
midgrade (nothing you can do so cut the pin section off for gold pin connector)
right peripheral
right telco
left top peripheral
left bottom. midgrade with the screen on, may be better depending on the back with the screen off
left peripheral
right midgrade
midgrade
silver/tin ram
left midgrade (barely)
right peripheral
these are really pushing the class premise but yes; gold finger card
top has limited ic but removing the copper spool and with the heavy gold port...
bottom has even less stuff but what it dose have is relatively decent.
telco (remove the screwed on bracket here and do NOT remove ICs)
midgrade, like the other one further up the list just cut the port off.
both peripheral. CAREFULLY remove the DALLAS box. it's a battery.
midgrade
peripheral
both peripheral
both peripheral. Do cut the wire as clean as you can to separate them
large socket, yes the circled IC and the three in the square sockets can be removed for IC rate.
metal socket. yes heatsinks need to be removed from the majority of items including this photo and video cards.
PostPosted: Sat Sep 22, 2018 5:25 pm
Thanks for your help lostinlodos.
This has gotten me through most of the pile. Found a couple more questions. This stuff looks equivalent to what I'm understanding is peripheral, would you agree?
And not sure about these ITX boards. Are some of these peripheral (the ones with the CPU hard mounted) and some metal socket?
Thanks.
PostPosted: Tue Sep 25, 2018 9:14 pm
20180922_135804.jpg)
peripheral, just barely
20180922_135606.jpg)
peripheral peripheral
telco midgrade (unless lots of ICs on back
peripheral
20180922_135503.jpg)
peripheral/midgrade (unless gold pins or ICs on back)
peripheral/midgrade
peripheral/midgrade/(top to bottom gold pin connector peripheral)
20180922_133445.jpg)
all peripheral
20180922_132813.jpg)
peripheral peripheral peripheral
telco (barely)
20180922_132538.jpg)
both peripheral
20180922_132459.jpg)
peripheral and gold finger card, correct
20180922_132221.jpg)
top yes if you pull the big piece off and the large capacitor and the aluminium (and you must remove the battery) then you will clear peripheral with the ICs left in the sockets.
Lower one always remove any pop-off shields. and it's peripheral
20180922_132120.jpg)
metal/large
metal/small
