It is currently Tue Nov 03, 2026 10:32 am
PostPosted: Thu Feb 12, 2015 9:38 pm
Does boardsort require the removal of all heat sinks attached to motherboards removed before shipment? I was just wondering cause I do not want to send my boards and then later on find out it was down graded just because I forgot to remove the heat sinks. Also what else needs to be removed from the board to get the best price. This is a large socket board I have and I was wondering if I need to remove the 2 aluminum heatsinks and the gold plugs
PostPosted: Thu Feb 12, 2015 11:26 pm
Remove the two heat sinks and the small battery as well. You should be good to go.
cron
