It is currently Thu Sep 10, 2026 5:28 pm
 Post subject: depouplation of borads
PostPosted: Sat May 10, 2014 2:26 pm
Do boards of any grade still hold any value to boards sort if they have had a number of there components depopulated? if not damaged.
PostPosted: Mon Jun 09, 2014 10:33 pm
more than likely, boards will be downgraded if components are removed. One example is a telecom board. If you depopulate all the IC chips, you will have a pile of IC chips and a board that is now mid-grade at best. The question you need to ask yourself before doing that type of work is if you will profit more separating the components vs selling the board as-is.
