It is currently Thu Sep 10, 2026 9:14 am
 Post subject: Ic chip removal
PostPosted: Wed Oct 25, 2023 6:39 am
What is the best method for ic chip removal you guys have found? Ten years ago most people just popped then with a screw driver or used pliers to snap them off. I cut legs on one side with mini cutters and then take off. Anyone have better options ? Thanks!
 Post subject: Re: Ic chip removal
PostPosted: Wed Oct 25, 2023 6:47 am
For board soldered ones, a box cutter works in a pinch. I use a jaguar knife myself.
For socketed scrap chips, screwdrivers work well. To salvage them though a chip remover is best.
PostPosted: Wed Oct 25, 2023 11:10 am
I have a putty knife that I have sharpened to a one-sided edge. It's about an inch wide so it fits in tight spaces. I also use it to remove transformers.
PostPosted: Wed Oct 25, 2023 4:42 pm
Thanks for the replies gentlemen. Now if i can sort boards as well as u ill be doin ok!
PostPosted: Wed Oct 25, 2023 5:26 pm
Remember the rule though.
Removing soldered chips from any board above midgrade is going to kill the buy value of the board.
PostPosted: Thu Oct 26, 2023 9:11 pm
Yes sir chris did tell me that like 10 years ago. I remember that! Back when mid grade was a different price then low grade! So u only took chips from low!
PostPosted: Sat Oct 28, 2023 10:22 am
Wood chisel, they come in different sizes, and still work fine if they get dull.
