It is currently Thu Sep 10, 2026 7:13 am
PostPosted: Mon May 11, 2026 9:52 pm
Hey all,
My most recent score of boards has heat sinks glued/pasted directly on the largest main chip on the board.
I attempted to do my normal twist and pop method with vicegrips; well it pulled the chip off too!
2nd method was to use a hammer and small screwdriver. This method worked on the additional 3 I processed.
Does anyone have any more efficient methods? I feel dumb for asking these questions. And now I have a “downgraded” board that was not supposed to be “downgraded” as all I was trying to do was clean the heatsink off.
I guess this is the only way I learn but messing up.
PostPosted: Tue May 12, 2026 9:14 am
I use some heat, lp torch works great just don't go crazy with the heat.
PostPosted: Tue May 12, 2026 9:36 am
Thank you! I believe I have a heat gun but I do not own a torch. I will see if I can order one on Amazon. Do you recall where you bought yours @lubin?
PostPosted: Tue May 12, 2026 10:10 am
Try the heat gun first. If it sounds/feels/looks like the chip is coming up after heating with the gun, try being a little more aggressive with the heat gun and try again before going with a torch.
You can get the little blue or yellow tanks from Walmart or your choice of hardware store. I think my current torch head was a gift, probably from Amazon
PostPosted: Tue May 12, 2026 11:12 am
I use a robogrip wrench and it takes care of 99% eg your vice grips.
I’ve done the same with a hammer and screwdriver.
Before resorting to heat I suggest torque.
Get one of those dirt cheap replaceable blade paint scrapers. The ones with a screw in the middle of the blade.
Remove the scree, recycle the scraper and blade.
The thick backing bracket fits into most chip sized sinks and allows you to use a wrench or hammer to torque the sink off.
PostPosted: Tue May 12, 2026 12:53 pm
A stiff putty knife works really well for me. Also if i can seperate the popped off chip from the heatsink, i will tape it back in place and write”sorry” on the tape. So far they have still accepted the boards without downgrading.
PostPosted: Tue May 12, 2026 2:10 pm
I truly thank everyone again for helping me out. You all are so kind and happy to have forum members that aren't condescending or rude to a novice like myself.
PostPosted: Tue May 12, 2026 3:24 pm
Yes. I find some people are downright nasty and mean over the internet. Never used to be that way back in mid-2000s on forums.
Just an update for anyone that might have a similar heatsink issue. I am using an old Milwaukee Heat Gun with two settings Low/High. I am using the Low setting. I apply heat directly over top the heatsink without touching for approximately 10 seconds. Lastly I use vice grips and the heatsinks pop off like you are pulling off candy buttons (remember them!).
