It is currently Wed May 27, 2026 4:20 pm
 Post subject: should I remove
PostPosted: Sun Feb 15, 2026 8:42 pm
Hey all,
Should I remove these 3 items in the pic to maximize grade or will it matter?
Thanks!
 Post subject: Re: should I remove
PostPosted: Sun Feb 15, 2026 9:54 pm
Silver box looks like an oscillator of some sort which is usually good to leave. I would probably remove the two converter boxes though. High telco once they're off.
PostPosted: Sun Feb 15, 2026 11:50 pm
Awesome, thanks!
PostPosted: Fri Apr 03, 2026 7:01 pm
That "silver box" is a crystal oscillator. So for future reference for you. When you see a Mhz after a number. On a component simliar to what you pointed out. Look for. For example 8 Mhz. 12 Mhz. Even a long number with a decimal point. 16.0000 Mhz. Or even 20.1184 Mhz. It's a crystal oscillator. As Marked141 said. Leave it on. They actually have silver content. Also Sometimes. You will see small crystals as I have uploaded and pictured unlabled. Again. Yes. Echoing what Marked141 Leave them.
So those Lucent boxes. I'm personally impressed by two Dc to Dc Converters on one circuit board. There is good e-scrap value in any PCB mounted DC to DC converter. Those Lucent modules operate at max efficiency. How do we get there. Gold. Yes sir. Leave them on also.
I am onboard with Marked141 with the category.
PostPosted: Tue May 26, 2026 3:16 am
I know that this is kinda missing the point of the topic at hand.., BUT!.,
IMO, I think it'd be easier to see your pointer arrows if you used a better contrasting color instead of that blue. I think most saw the 3 things you were referencing way before noticing the arrows pointing at them?..? At least it was for me, no biggie though!
Just my 2 cents :D
