It is currently Sat Oct 31, 2026 12:13 pm
 Post subject: Gold pin telcom boards
PostPosted: Thu Jan 24, 2019 2:38 pm
I have a small handful of these boards. Ship as is or salvage the pins for shipping and toss the board?
PostPosted: Thu Jan 24, 2019 4:05 pm
As is it will go as a hidden category called pin board. Payout is higher than normal classes, it lower than raw pins. The value is a percentage of the raw pin value.
When you send them in they will test the pins and quote out based on the materials value.
You could remove all the pins (not me, too much work there), and get even higher payouts on the pins, or send them whole.
PostPosted: Wed Jan 30, 2019 11:04 pm
In the same vein, your Telcom board line item mentions that photos are requested before shipping. Post them here? EMail to whom? I have 22 different board models.
PostPosted: Thu Jan 31, 2019 12:46 pm
9 times out of ten if you’ve posted items here you’re good to go and don’t need to re send them. Unless someone says they’re too borderline to call.
Otherwise you can send them to Chris at boardsort dot com
PostPosted: Thu Jan 31, 2019 4:26 pm
Sent. Thank you
