It is currently Tue Oct 27, 2026 11:10 pm
 Post subject: Chips?
PostPosted: Tue Feb 02, 2021 6:46 pm
Hi,
Please are these (the highlighted) chips? If no, should i remove or leave on the board?
 Post subject: Re: Chips?
PostPosted: Tue Feb 02, 2021 8:20 pm
one is a CPU and one is a bridge ASIC. one is in a socket (turn the screw and it will free up and you can pull it out) and one is soldered. remove the socketed one (likely green fibre no metal) and leave the soldered on. That's a laptop class board.
PostPosted: Tue Feb 02, 2021 8:36 pm
Thank you lostinlodos.
Since the boards are going to a refiner, do i just leave both on the board?
Also what class are laptop boards, mid or high?
PostPosted: Tue Feb 02, 2021 8:40 pm
leave them on.
and for most companies it would be midgrade.
do pop the wire out and remove the tape, bottom left. make sure there's no button cell battery under that.
PostPosted: Tue Feb 02, 2021 9:16 pm
thank you once again. appreciate the help
do those chips by any chance contain precious metals too?
PostPosted: Tue Feb 02, 2021 10:46 pm
Absolutely! Both are on Chris’s list (green fibre no metal, and flat pack with tab).
All ICs (integrated circuits) have PM.
