It is currently Thu Oct 29, 2026 1:14 am
PostPosted: Sun Feb 07, 2021 1:48 am
I was wondering if you normally remove components like soldered-in relays or inductors from boards, or is it better leave them for the weight? Or do they downgrade boards? I have a good pile of them because I've been removing them, but its a bit of work and prep and i'm wondering if its worth it. I could do numbers but its hard to tell since they vary so much in weight. Does anyone have any advice or experience?
Thanks!
PostPosted: Sun Dec 19, 2021 1:52 pm
I guess you have figured out the answer that satisfies you by now, 10 months later. If the board is anything other than a low or midgrade board or power supply board, yes, remove all the heavy metal/copper/heatsinks leaving only the other valuable components. With the transformers and toroids, not likely to go above 50 cents per pound, and shipping is roughly a dollar a pound, so why loose money...in fact you cannot economically ship any board worth less than a dollar a pound. Since I deliver in person, I leave the heavys on the low and midgrade, Back when the low/mid were less than 20 cents per pound, it was profitable to strip the heavys and sell locally.
