It is currently Thu Oct 29, 2026 3:29 am
PostPosted: Sat Jan 15, 2022 12:43 pm
Hello, for best pricing results, should the CPU's and memory be removed from the motherboard? Is the listed price for large & small socket motherboards with CPU and memory installed?
PostPosted: Sat Jan 15, 2022 12:47 pm
ram and cpus have their own categories that pay much higher than the motherboard. refer to the payout rates and you will see the significant difference for yourself.
PostPosted: Sat Jan 15, 2022 4:58 pm
Thank very good to know. Another questions please. For the CPU's (AMD & Celeron) is it recommended or necessary to remove the thin metal plate heat sink shield on the CPU's?
PostPosted: Sat Jan 15, 2022 6:58 pm
That would fall under "AMD Ceramic Aluminum Top K6"
I wouldn't remove it.
PostPosted: Sat Jan 15, 2022 7:14 pm
Without the shield if you don’t break the chip, it’s AMD ceramic no metal. Use gentle aggression from the corners with a flat (standard) screwdriver to pop the top if you try.
