It is currently Fri Oct 30, 2026 9:51 pm
 Post subject: Capacitors
PostPosted: Mon Nov 06, 2023 6:36 am
My son was starting to remove caps from the boards are tese of value and should they be removed?
 Post subject: Re: Capacitors
PostPosted: Mon Nov 06, 2023 7:09 pm
Generally you don’t have to remove them unless they are gigantic (eg 1/4 the weight of the board).
Canister capacitors contain oil and aluminium. Some steel buyers will pay a sealed unit rate for them, as if they were hydraulic cylinders or cooling canisters.
Boardsort doesn’t buy them directly.
PostPosted: Mon Nov 06, 2023 7:20 pm
Ok so by removing them it will not affect the price correct? I have a way to nuetralize the oil and smash them flat.
PostPosted: Mon Nov 06, 2023 8:12 pm
Only by lowering the weight of the board.
I tend to remove them myself generally as replacement parts.
