It is currently Fri Aug 14, 2026 3:27 am
 Post subject: WinTV cards
PostPosted: Fri Jan 30, 2026 9:02 pm
I have a few different versions of these but same general idea. Do I need to pull the box off before sending as GFC?
 Post subject: Re: WinTV cards
PostPosted: Fri Jan 30, 2026 9:48 pm
You need to remove the top shield/cover at the very least; this removes some low value weight and allows Boardsort sorters to easily see what's in there. Removing the box isn't strictly necessary.
Most boxes like that have steel all the way around but depending on the particular board it's near impossible to remove both sides without removing the entire box.
It's been a minute since I've seen one of those so I'm not certain how that affects the grade off the top of my head.
PostPosted: Sat May 16, 2026 1:26 pm
OP if you are having trouble removing the box grab some angle pliers or angle cutters or angle snips (whatever you may call them). Then you will want to work on the sides/ends of the metal incasement. I thought they were going to be trouble but I was able to remove quite a few for my most recent shipment to boardsort.
