It is currently Thu Apr 30, 2026 9:35 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: IBM PC Server 720
PostPosted: Thu Apr 16, 2026 11:08 am
austin86 wrote:
obix are you willing to ship the server to Ohio? and how many CPU cards does it have ?
Sure, I'm willing to package it up and ship it if you're up for the shipping cost. I'm not sure what method would be best, probably some sort of ground? You all have far more experience with shipping I'm sure.
I'll check on the CPU(s) today, I know it has at least one if that's helpful :D . The challenge atm is to get a driver for the RAID controller, that was the bigger obstacle I was coming up against yesterday.
Type: IBM SCSI-2 Fast/Wide Streaming-RAID Adapter/A
FWver: 2.21
I even tried a WinNT Small BackOffice Server install but it really wants the support for the SCSI and RAID in first...
P.S. - I was reading the posts on the PM situation, how frustrating when useful tools get abused. I'm wondering if there's a way to start a "Trusted/Privileged" group that a member can be added to just to add that ability, or have private conversation just within that group?
PostPosted: Thu Apr 16, 2026 11:18 am
FWver: 2.21
https://www.ibm.com/support/pages/ibm-s ... 31-servers
That might be the cards driver.
If you give me your zip I can get a rough idea of the shipping cost, or at least for the label. If shipping is not outrageous and it has at least 2 CPUs cards I'll shoot you an offer. If my offer is to low or shipping is crazy high I know someone who would also likely buy it and I can give you his info.
PostPosted: Thu Apr 16, 2026 12:03 pm
austin86 wrote:
lostinlodos wrote:
Click on profile, then click the email if it’s public you can contact
profiles are not clicky for me.
Oh. I thought the little profile icon showed up at the bottom left of the post for the user. Sorry.
PostPosted: Thu Apr 16, 2026 1:31 pm
nope, not for us plebs lol.
I'll post my email then remove it once he replies after he gives me a zip code to see if the shipping will be outrageous or not.
PostPosted: Fri Apr 17, 2026 2:13 pm
austin86 wrote:
zip code
there are several in my area, not sure if it will make a difference: 59101, 59102, 59106, 59044
Well an update...
I finally got a copy of the SCSI/RAID controller drivers (IBM only allows sftp connections now and I never could get it to authenticate with my credentials.. ardent-tool.com is the bomb!) and got the RAID configuration utility to come up. It showed the RAID-5 in good health but the install was corrupt so it still wasn't booting. Then shortly after it suddenly just powered off, not shutdown, just off. This has "shutting-off" has continued, but shutting down even quicker (like a failing component).
I cleaned/checked the PSU and there doesn't seem to be any apparent issue, caps all visually look good and as the power levels are dead on and the front power indicator lights all show power is good I decided not to pull the pcb's and go further with testing the caps for now.
There seems to be some indication that the memory board isn't working correctly. I removed/cleaned/re-seated everything but no change. When first powered on the led at the end of the memory board socket on the main board comes on for 1-2 sec's then dimly flashes twice then stays off. This behavior is the same with the board in the second memory board socket also.
I've re-seated everything multiple times, alternately removed drives etc and nothing seems to get me past POST now. The main board appears to have been re-cap'd before I got it but it looks like decent work was done. The strange thing is the first day I started it up it ran all day, like 6-7 hours straight with zero issues (of this type). Then after pulling the boards for cleaning and inspection yesterday this problem began.
I'm inclined to think that the movement to these old dry boards must have lifted a pad somewhere or created a cold solder joint. I spent the past 1.5 hours with the boards under my microscope camera but the problem hasn't changed.
So sorry to say, it is not a functioning machine atm and I don't have any more time to give it until probably next fall (I have an annual farmers type schedule). I just wanted to update and not leave you hanging on this one.
PostPosted: Fri Apr 17, 2026 2:55 pm
Just break it up so it can’t be picked up by scanners and spiders
Name residing at location
Dang that's a kick in the nads. If I had any more drop in ATX panels I would buy it for the case and put a dual slot one or socket 8 board in it. Give luckybob a jingle on vcfed or vogons he may still buy it.
However if you find anything else like this do let me know !
PostPosted: Fri Apr 17, 2026 2:57 pm
I was going to post a alias address.
PostPosted: Sun Apr 19, 2026 6:33 pm
Ok, so I couldn't leave it alone. I had to at least know if it was the system or PSU, soooo I made a custom adapter that allows for a regular ATX PSU to be used on it.
Before when I back-probed the Power_Good pin on the original PSU it was always below 0.4V. With this setup it ranges between 3.5V - 5V but pretty stable at 4.860V AND it's been running for 3.5 hours now w/o crashing a single time!!!
So. It's the PSU.
Pretty sure it will be either a cap or voltage regulator. As far as I can tell there's nothing wrong with any of the other hardware, I'm re-sync'ing the RAID-5 now to see if it's recoverable, if not I'll wipe it and start fresh, probably with WinNT.
PostPosted: Mon Apr 20, 2026 12:27 am
that's a odd way of rigging a atx psu to work with it.
