lostinlodos wrote:
WebEstatesEWasteSolutions wrote:
It's a well known process that produces low quality "fuel" if you even want to call it that.... and is a net negative ROI
It's a complete waste of time
Only a waste for a small user. Commercial, it’s got potential.
Multiple facilities exist creating such recovered fuel already in the U.S. and around the world.
What you generally wind up, from my understanding, is a very
Low end diesel fuel.
I’ll also mention that I’ve driven heavy equipment in the Arctic long before the idiocy of the ice road shows came out. I’ve seen mixes used in some countries that use recovered plastic as an additive as it doesn’t freeze as high as diesel.
I love diesel engines. You can literally put anything in the tank and it'll go!
I think my main problem is that they're pitching it as a gasoline replacement. They did some videos where they put it in a scat pack and a rolls royce?
I don't know if that whole thing is some elaborate scam or what but the methods he uses are well known. If your goal is only to turn plastic waste into fuel at any cost then it's fine but don't pitch it as some revolutionary gas replacement produce that the government doesn't want you to know about
