It is currently Sat Nov 07, 2026 1:29 pm
 Post subject: damaged baords
PostPosted: Fri Oct 10, 2014 12:12 pm
What happens if. Board is cut in half or broken? Since they are being brought for PM content does it make a difference in price?
 Post subject: Re: damaged baords
PostPosted: Fri Oct 10, 2014 12:33 pm
What I would do is keep all the pieces of the broken board together when you send them to boardsort and let boardsort look at them. If you break a board into two pieces, of which one was heavily populated with IC chips while the other piece had little to no IC population, the side with all the IC chips may fetch telecom grade while the other piece would go as mid-grade.
