We now buy Yellow and Black Tantalum SMD
We are offering to buy certain Tantalum capacitors. They must be the SMD type (surface mount) and be either yellow or black.
Here is the catch. You can mix the yellow and black together with no problem, BUT there must be ONLY yellow and black tantalum in your mix. If there are items other than yellow and/or black SMD tantalum in your collection, it will be purchased at a ridiculously low price. The reason being is that it is extremely time consuming for our staff to clean contaminated SMD's and we must pass that cost on.
Having said that, if you are concerned if your mix of SMD tantalum is not up to snuff, you may consider sending a small sample first to make sure you are processing and sorting correctly.
You will find the the current price of our Tantalum SMD listed under the Hardware section of our pricelist.
[edit by lostinlodos]
I’m going to temporarily interject. Having sold tantalum to another set of buyers in the past, regularly and for many many years:
Until Chris clarifies or modifies this clean means clean.
No solder. No mounts. No nickel or tin pins. No PCB. No brackets. No fins.
