It is currently Fri May 01, 2026 3:06 am
PostPosted: Thu Mar 05, 2026 11:05 pm
Hello,
I have several boards I’m looking to identify and get a price estimate for. I have attached photos of the each board below.
Could you please help me with the grading and the current price per pound for these?
Thank you!
PostPosted: Fri Mar 06, 2026 9:56 am
These are likely somewhere between high peripheral and Telco. You'll also have a power supply board in one, that could be low or mid grade.
You'll want to remove the boards completely from the housings. Also unplug any cables and remove heatsinks. Then take front and back photos (unless there's absolutely nothing on one side) for a more accurate grade.
On the 6.41.22 image I see what may be brass flashing on the housing you can peel off too.
PostPosted: Fri Mar 06, 2026 10:11 pm
Step 1
Remove the fans and wires
Step 2
Remove the steel. Looks like the shells are righted so a 1” type a carbide or titanium bit will drill through and allow removal
Unscrew what you can first
Step 3
Sell for high peripheral
