It is currently Mon Nov 09, 2026 12:01 pm
 Post subject: What is this board?
PostPosted: Thu Nov 05, 2026 11:52 am
This board came from a series of network antennas, I'm curious to know what category this will fall under, it looks similar to a cell phone boards but perhaps that's wishful thinking, can anyone steer me correctly?
 Post subject: Re: What is this board?
PostPosted: Thu Nov 05, 2026 4:37 pm
Gonna need better photos to give the most accurate opinion. If there's components on both sides then a top and bottom pic.
PostPosted: Sun Nov 08, 2026 1:11 pm
This is the other side
PostPosted: Sun Nov 08, 2026 6:27 pm
Weird, did you have the first image (that you reposted in the what is it? section) when I replied? I don't remember seeing it.
Anywho...as mentioned in the other post, not sure what the metal boxes are on the other side, remind me of ethernet style ports but the underside looks like something different would be there. Depending what's there (what the metal is made of and what is in it), the metal may need to be removed or it may be fine. The large shield on the back should be removed, the smaller square ones, probably can stay but if you can get one off easy, go ahead and get them all.
Then are the boards heavy? Like if you picked up any random similar size board does this one feel significantly heavier? Could be indicative of higher gold content common in the gold edge category.
Tentatively I'd say at least high peripheral with a decent chance of a telco grade but need more info still
