It is currently Tue Nov 03, 2026 2:34 am
PostPosted: Tue Sep 08, 2015 7:46 pm
These are not connector ends and have not been removed from
a board the pins are long and straight encased in plastic
in a slot array value close to that of fingers and cpu pins if only because of
large amount of gold plating
PostPosted: Tue Sep 08, 2015 10:18 pm
You'd have to post a picture to know what you're talking about.
PostPosted: Thu Sep 10, 2015 8:17 pm
I will try to upload photos
PostPosted: Thu Sep 10, 2015 9:38 pm
url=http://www.boardsort.com/escrapforum/viewtopic.php?p=4633#p4633]Subject: slots with long pins not processors not yet used on boards[/url]
The top one is a crimp adaptor. It's a standard gold pin connector. Remove the plastic by cutting the centre with a tin snip and the free pins will come loose rather easily.
Middle and bottom look like wholesale parts that didn't get used. Both would fetch gold plated pin rate but you'll have to email chris and ask for a quote. Add the pins from the top one with it.
PostPosted: Thu Sep 10, 2015 10:02 pm
Does boardsort. Buy the pins-- price per pound?
PostPosted: Thu Sep 10, 2015 11:02 pm
Yes; but you need to email them for a quote service and once you send them in they will scan them and price it out based on ammount of gold in the plating (kt rate) and thickness (umt).
