It is currently Tue Nov 03, 2026 9:02 am
 Post subject: i486 DX2 Chip
PostPosted: Tue Jul 14, 2015 8:52 pm
I have a few Intel i486 DX2 CPU chips with a blue aluminum heat sink attached. I've tried several way of dis-attaching the heat sink, but to no avail. Any suggestions?? Will Boardsort purchase these CPUs with the heat sink attached??
Thanks..
 Post subject: Re: i486 DX2 Chip
PostPosted: Wed Jul 15, 2015 3:28 am
Did you try a heat gun? They tend to pop loose when the thermal consistency reaches about 300°F
Set a gun to 650-800 or "high" on fixed settings guns. Takes about 30-45 seconds
As an alternative a propane touch works in a pinch.
PostPosted: Thu Jul 16, 2015 2:03 pm
Thanks... I was hesitant to heat in fear is may cause damage.
Al
PostPosted: Thu Jul 16, 2015 2:35 pm
Safety gear.
Two pliers or tongs or locking wrenches
Safety glasses.
Using heat gun set it directly above the heat sinc sinc-side-up.
Wait about 45 seconds
Grab top fins of sinc with your grippers.and lift up slightly . Gently bang side of of sinc with other grippers
Should pop loose for you on the vibrations alone. With a nice little pop sound.
Caution all items will be hot after heating. ;)
