It is currently Sun Nov 08, 2026 3:26 am
 Post subject: Sorting motherboards
PostPosted: Thu Sep 05, 2019 3:51 pm
Do I have to separate laptop motherboards from large socket motherboards? Can green metal socket and green small socket motherboards get mixed? Same with the colored motherboards? That is what it says in the payout section for the categories of motherboards.
Thank you!
 Post subject: Re: Sorting motherboards
PostPosted: Thu Sep 05, 2019 11:13 pm
Motherboards should always be sorted by class regardless of pricing.
The only exception is laptop motherboards can be grouped with large socket since they’re classed as such
PostPosted: Fri Sep 06, 2019 7:00 am
so there is no difference in laptop motherboards? Like a Pentium 3 motherboard has the same value as a i7 motherboard?
PostPosted: Fri Sep 06, 2019 1:31 pm
Keeping in mind things like net books are excluded, then yes. You are correct.
The reason being laptop boards condense an entire computer into a single board. Less size, more components. Actually an i7 desktop motherboard would almost always be metal socket. Where an i7 in a laptop is normally soldered, this being a laptop motherboard for large socket rate.
PostPosted: Fri Sep 06, 2019 3:49 pm
Thank you.
