It is currently Mon Sep 21, 2026 4:06 am
 Post subject: Gold Pins
PostPosted: Mon Aug 23, 2021 9:07 am
When removing gold pins, if the entire pin is not gold plated does BoardSort require you to trim all of the non gold portions off or do you/can you just send the phone pin?
 Post subject: Re: Gold Pins
PostPosted: Mon Aug 23, 2021 1:13 pm
Most pins aren’t fully plated. Use your best logic. Obviously if the pins are a half inch long and only the tip is plated it won’t fly.
Something like VGA pins … as long as the majority is gold plate you’re good.
