It is currently Tue Sep 22, 2026 4:02 pm
 Post subject: Removing shields
PostPosted: Mon May 19, 2025 3:38 pm
The difference of (today) $12 and $32 is substantial enough that most people will do the work.
That said here’s my plan. If you have a bench drill or press riveted shields are easy. Most above have some sort of compression lock. Stack the ram up and snap the rivets out. 99% of the time the shields then simply fall off by banging the stack.
The manual method; use tin snips. You can cut the rivets on the inside edge of the circle. Cut through the board, the rivet, and the shield. Then see below.
For standard shields I do the quick screwdriver test. (Actual I use the backing brace from a paint scraper, it’s thicker, wider, and more torque).
Pop left pop right if the shield comes off first try good if not it’s shielded ram.
 Post subject: Re: Removing shields
PostPosted: Thu Apr 30, 2026 12:37 pm
Good idea with rivets. For me. If the shield doesn't basically fall off. I always put the heat gun to it. I had too experiences with ram chip pulling off and sticking to the shield.
