It is currently Mon Oct 26, 2026 2:39 pm
PostPosted: Tue Mar 10, 2026 1:57 pm
Trying to figure out how this card would be classified for scrap (see pic).
If I remove the heatsink and bracket, would this count as a clean gold finger card?
I believe the capacitors need to come off also. If so, is cutting them off fine or do they need to be desoldered?
Or is this just considered a lower grade board no matter what?
PostPosted: Tue Mar 10, 2026 2:42 pm
I would just remove the bracket and the heat sink. Then submit as Gold Finger Card. As a consideration. Some individuals leave the bracket on and claim a better payout. Do a forum search. You will find the bracket issue addressed. Now. For me. I mail in. So. I need space in my box. The brackets take too much space up. They keep me from packing as tightly as possible. Being able to put a few more RAM or high priced CPU in my package does more to offset shipping costs than that bracket weight.
My grade evaluations are my own opinion.
PostPosted: Tue Mar 10, 2026 2:51 pm
No need to remove any components that are soldered on.
I prefer to take off heatsinks and brackets.
If that is covered in ICs the way it appears you may actually get a high Telco grade for it.
Do remember to utilize the What is it? section of the forum for help with grading.
PostPosted: Tue Mar 10, 2026 3:15 pm
It is a fusion io board
image attached without heat sync from a source google not identical but near same
https://en.wikipedia.org/wiki/Fusion-io
PostPosted: Tue Mar 10, 2026 4:28 pm
Looks like a ssd or general computing board
The first board without the heat sink is probably high Telco
The second board: There’s not enough for high telco (on the top ) so clean gold finger card unless the bottom is equally populated
The capacitors are fine
cron
