It is currently Wed Oct 28, 2026 4:51 am
PostPosted: Tue May 20, 2014 2:58 pm
Please tell me what I have here and how to sort it.
Motherboards - 5,000pcs
PSUs - 10,000pcs
RAM - 20lbs.+
40-pin Flash - 5lbs.+
VGA cards - 10,000pcs
(I work for a PC repair company)
PostPosted: Tue May 20, 2014 8:29 pm
Motherboards: remove the heat sinks to determine sockets size (large or small)
PSU: Is a low grade and unless you are located near Boardsort it is better to sell it to your local recycler.
RAM: separate by gold and tin/silver fingers.
VGA Card: it seems to be a Peripheral grade and you have to remove the metal square cap and wires.
Please refer to the forums for detail info about sorting and shipping.
Hope this helps a bit.
PostPosted: Tue May 20, 2014 10:15 pm
Also remove all batteries from the boards.
PostPosted: Thu May 22, 2014 2:49 pm
PSUs i remove the wire for stripping or selling as is and scrap the main unit.
Motherboards can vary, If its from a laptop it will always be considered a large socket, but desktop/other motherboards must be segregated by socket size. I cant recall the exact measurements but it should be on the payout prices.
Good thing you saved all that stuff eh?
