It is currently Mon Aug 03, 2026 10:29 pm
 Post subject: Board Grade
PostPosted: Thu Dec 28, 2017 5:39 pm
Hi there - can anyone tell me what this board is? Under the silver metal squares there is a small transformer. But, it has gold fingers, as well. Should I cut the fingers off? Thanks!
 Post subject: Re: Board Grade
PostPosted: Thu Dec 28, 2017 11:41 pm
If there’s ICs on the back it will just barely make it as peripheral with the fingers on
If no ICs cut the fingers off, the board will be midgrade either way in that case.
PostPosted: Fri Dec 29, 2017 3:20 pm
Thank you for your help lostinlodos! There are no IC chips on the back, so we will cut the fingers off.
PostPosted: Fri Dec 29, 2017 6:54 pm
Choppy choppy
