It is currently Fri Oct 30, 2026 3:56 am
PostPosted: Sun Feb 11, 2018 2:42 pm
Have some small boards and cable ends to ID
PostPosted: Sun Feb 11, 2018 5:15 pm
Two of the boards (both are laptop trackpad boards) are probably peripheral. The laptop mouse button board is probably midgrade. The item below these boards is a PCIe x16 riser cable. I am not sure of the category into which the cable goes, but you can at least trim the gold fingers.
PostPosted: Sun Feb 11, 2018 5:24 pm
Sam has it.
Cut the finger end off the wire. That will get clean gold fingers.cut the socket nd off the other side. That gets gold pin connector.
Finally boardsort buys the remaining cable as mixed wire. Or locally you’d get low grade insulated wire, or harness wire.
PostPosted: Sun Feb 11, 2018 8:11 pm
Thanks much guys.
