It is currently Fri Oct 30, 2026 2:45 pm
 Post subject: I’d please
PostPosted: Thu Feb 15, 2018 2:10 am
If I remove the chips from the board what category they would fall in to?
What category would they be if I keep them on the board?
Thanks a lot
 Post subject: Re: I’d please
PostPosted: Thu Feb 15, 2018 2:36 am
I have some almost like them. As is peripheral, I would venture to say if you pull the chip the board wiould go midgrade. As far as the chips I'm not sure.
PostPosted: Thu Feb 15, 2018 3:08 am
Yes, on everything
Chips alone get ic rate.
PostPosted: Thu Feb 15, 2018 10:12 am
If I remove the chips wouldn’t I get better than ic chips since the legs are gold plated?
PostPosted: Thu Feb 15, 2018 10:46 pm
They’re not truely socketed. So the legs aren’t accounted for. If you manage to desolder them and keep the short legs you may get as high as green fibre with metal but that would be up to Chris and only if you manage to keep all the legs intact.
But no, these are not CPUs, more large enough PEPs to make DLP class. Hence they go as IC chips.
