It is currently Mon Nov 02, 2026 11:31 pm
PostPosted: Wed Apr 25, 2018 8:04 pm
Everything below came from a TimeWarner server rack, ive got full size boards and half size boards, i assume they all go as telco?
These first two pics are of a double board, one ontop of the other.
these are all the same as the first ones except single boards.
would this go in the 386/486 grade? its a Intel i960, solid ceramic top.
And then there are these...
PostPosted: Thu Apr 26, 2018 5:13 pm
Back tonight. Especially here. I need to match these up to what I’ve sent since there’s some class benders here
PostPosted: Fri Apr 27, 2018 9:04 am
the big boards should all go as telecom. The i960 is considered 386/486. the board with the heat sink and metal cage is hard to tell because we don't know whats underneath... if you can remove them, you should. The small board with three wheelie thingies looks like it would be peripheral from what i can see in the pic.
PostPosted: Fri Apr 27, 2018 1:11 pm
Thanks mls. Absolutely perfect
PostPosted: Fri Apr 27, 2018 6:04 pm
thank you!
