It is currently Sat Nov 07, 2026 1:39 pm
PostPosted: Thu Jun 14, 2018 2:38 pm
I saw a few other posts on this that didn't really help me out...
What will board sort pay for gold plated connector pins that have been removed from the plugs and cleaned of all solder? Will they take them as clean fingers?
PostPosted: Fri Jun 15, 2018 2:52 am
no one here can give you a qoute on these item they are graded then priced in person....
no....
^that being said if you post some pics we might be able to give you A ball park
estimate based on are own experiences.
PostPosted: Fri Jun 15, 2018 3:45 pm
no they will not take them as gold fingers... that is what they call the male gold connectors on things like video/sound/PCI cards (like in the Boardsort.com logo at the top of the page). They have a pretty constant yield rate as long as they are close cut. what you are talking about are gold plated pin connectors. yes they will take them at a different rate that 'connector ends', but they have to see them to assess them. you would need to get ahold of chris for that info.
PostPosted: Fri Jun 15, 2018 11:18 pm
A collector has descended excellent!!..
PostPosted: Sat Jun 16, 2018 12:43 pm
Gold pins need to be shipped with a quote order of some other item. They are scanned with an XRF unit that lists the exact quality and quantity of all materials in the pins; gold, nickel, iron, carbon, etc.
They then pay you based on the actual gold content of the pins.
PostPosted: Sat Jun 16, 2018 2:30 pm
Thank you guys for all the help! I think I'll contact boardsort before my first shipment and see about throwing the pins in with everything else!
PostPosted: Sat Jun 16, 2018 5:59 pm
Side question; evil... did you do that by hand or use an app.
I used to do ascii art but I cannot find a terminal level text program for modern systems that uses fixed width and height fonts using ascii. Everything saving it as <text> and it’s terrible on reopening later. Notepad++ was awesom in Windows 10 but it won’t compile with brew! :’(
PostPosted: Sat Jun 16, 2018 8:23 pm
I used to do ascii art but I cannot find a terminal level text program for modern systems that uses fixed width and height fonts using ascii. Everything Semarang it as <text> and it’s terrible on reopening later. Notepad++ was awesom in Windows 10 but it won’t compile with brew! :’(
got from WEBSITE there is a way to make your own .kinda crude really but click [[on the draw your own ]]
https://fsymbols.com/text-art/
[draw your own url]
https://fsymbols.com/draw/
PostPosted: Sat Jun 16, 2018 9:57 pm
And I believe we bot just showed out vintage. Lol
Thanks; will look.
SORRY CalebCutts for hijacking your thread.
