It is currently Wed Oct 28, 2026 3:40 am
 Post subject: Advice
PostPosted: Sat Sep 27, 2014 6:19 pm
I need some input on the best way to sell this board. Its an expansion board, gold fingered card, large socket and telecom all at the same time. I wasthinking trim the fingers and sell it as telecom. Those are huge fingers.
 Post subject: Re: Advice
PostPosted: Sun Sep 28, 2014 7:51 am
If the CPU can be removed, remove it. It appears to be socketed. If a gold cap is on the bottom, it's 386/486, otherwise pentium ceramic. What's left will go as telecom if you leave the fingers off. Trimming the fingers I believe will make it a large socket motherboard. Selling the card as-is I believe will get you gold cap high grade.
PostPosted: Sun Sep 28, 2014 9:09 pm
I cut the fingers off, and took out the CPU, I had just not taken it out when I took the photo. It should be high grade board just on tge size of the chips and quanity I'd hope, but those where some heavy fingers.
