It is currently Thu Oct 29, 2026 8:35 pm
PostPosted: Fri Oct 17, 2014 8:31 pm
Where to sort
PostPosted: Sat Oct 18, 2014 12:22 am
Photo 1 - I'd remove the white chip from it's socket and sell on Ebay. It'll probably go for more than 10 pounds of telecom. With it gone the lowest grade that board can go for is finger board. And it may well be the highest it can go for with or without the white chip.
PostPosted: Sat Oct 18, 2014 10:50 am
What is that white chip?
PostPosted: Sat Oct 18, 2014 5:27 pm
First photo will go as a fingered card. I would like to know what it came out of that someone would want to pay $30 or more for it on ebay.
Second photo is fingered card, but I would remove the socketed ICs because they appear to have gold caps and gold pins on those and you may get more selling those separate as you would leaving them on the card.
Third photo will go as a backplane.
Fourth and fifth photos are fingered cards. I'm assuming your last photo is of the last two cards from the opposite side.
PostPosted: Sat Oct 18, 2014 6:08 pm
The firsr photo, if you sell it to boardsort, cut off the blank board, throw it in mid grade and the rest will go high grade or ”telecom”
PostPosted: Sat Oct 18, 2014 6:14 pm
The double reasob you'll get there telecom price is the IC population and density, that alone its a good chance, add the gold finger its for sure, two fingers I'll put $100 on it. This is out of Mikes mouth just yestetday at the scale, so its not just my opinion, but I'd buy it high grade myself, if you use a pair of snips and trim the blank board.
