It is currently Fri Sep 18, 2026 6:47 pm
 Post subject: What is this?
PostPosted: Thu Feb 06, 2020 9:57 pm
Is there any value above peripheral to any of this? All you can see in the picture is a pallet with boxes.
25-Alarm Processor Board (PB-2000 w/Modem), 330-Remote Input Module (RIM-8), 43- Four Wire Interface Module (FIM-4), 75-Telecommunication Board, 7- Aiphone door module, 14- Aiphone base station, and 16- Aiphone network module. All quaintities are approximate
 Post subject: Re: What is this?
PostPosted: Thu Feb 06, 2020 10:29 pm
No pictures, or they’re invisible. Either way I can’t tell at the moment
PostPosted: Thu Feb 06, 2020 10:52 pm
I didn’t post a picture because you cant make heads or tales out of it lol.
I have tried searching some of the contents from the text description and still not having any luck.
PostPosted: Fri Feb 07, 2020 4:02 pm
Well, if nothing else cardboard can run 1-5 cents per pound in bulk. (50lbs or more).
From what I can find online it looks like upper mid range surveillance and communications equipment. My guess would be mostly peripheral with some low telco boards here and there, and some mid or low grade boards for power.
PostPosted: Fri Feb 07, 2020 4:12 pm
The more I look the more o believe the above to be accurate. Looks like controlled access equipment. Like for an office or apartment complex. Video, phone systems, access alarms, AAoTel equipment.
There’s some resale value of it works or is repairable. As scrap photos of the equipment, of that that I could quickly find, all look to be about 50/50 weight.
So figure half a listed weight to be escrap and the majority of that to be peripheral.
All for guessing. I can’t tell for sure.
Most looks peripheral. The NM would be the score of the lot scrap wise. As it may be a full ATX motherboard server based on the size and not an embedded VIA system. So there’s the possibility of standard computing components. Eg processor, ram, storage drive or cards.
PostPosted: Sat Feb 08, 2020 10:11 am
This lot is in Garland which is 2-1/2 hour drive from me. I haven't decided to bid on it just yet.
