It is currently Tue Mar 24, 2026 7:11 pm
 Post subject: help to identify
PostPosted: Fri Feb 28, 2020 5:36 am
High Grade Telecom or Gold Cap Chip Board please help
Added desktop Card Readers What group do they fall under thanks
 Post subject: Re: help to identify
PostPosted: Fri Feb 28, 2020 11:00 am
I don't see any gold cap chips in those pics, the one on the left should make hi telco but the other 2 prolly only peripheral, maybe low telco, the card readers are peripheral
Representin otown, central FL
PostPosted: Fri Feb 28, 2020 12:36 pm
pull the battery third picture
PostPosted: Fri Feb 28, 2020 1:02 pm
Peripheral
peripheral
Peripheral/peripheral
Gold finger card w bracket/low telco (note)
Note:As is right one is low telco.
Remove the heat sinks for clean gold finger card w bracket
Please remove batteries
PostPosted: Fri Feb 28, 2020 2:15 pm
Thanks so much both Large PCI Cards guess Low Telecom means PCI
PostPosted: Fri Feb 28, 2020 4:35 pm
Not necessarily. I downgrade the right one slightly because of the heat sinks. Not enough to be the lower dirty class of finger card boards; but more than the correct class can handle.
If you remove the two small heatsinks it will bounce the board to standard gold finger card class.
Arg: right card in small view. Left card in large view. It’s rotating again
PostPosted: Fri Feb 28, 2020 11:00 pm
Opossum,
Maybe these pictures will help :) these are a few examples of gold cap chip boards.
PostPosted: Sat Feb 29, 2020 1:22 am
That last one needs heat sinks removed. ;)
PostPosted: Sat Feb 29, 2020 9:04 am
I know, I know......lol actually they already are.
PostPosted: Sun Mar 01, 2020 6:05 am
How about these?
